DHCP relay depreciated commands
xuanChocolate96
Post by xuanChocolate96 »
Pretty new to switching and routing and have quick question on command differences between versions. New hardware replacing old switches, old switch runs on 6.4.3.479.R01 while new runs on 8.9.107.R02, as a result, there are a number of depreciated commands in between them.
The old configuration is as follows:
ip helper per-vlan only
ip helper address xx.xx.xx.xx vlan 148
ip interface "example1" address xxx.x.x.x mask 255.255.0.0 vlan 201 primary ifindex 2
ip interface "example2" address xxx.xx.xxx.xxx mask 255.255.254.0 vlan 201 ifindex 3
Given that ip helper is depreciated in the new version, how do I translate the configuration over to the new switch? Do I need to enable per-interface mode and create an entry for each of the two interfaces?
Re: DHCP relay depreciated commands
correct. The ip helper is replaced by ip dhcp relay. And per-vlan is now per-interface.
BR Silvio
Return to “OmniSwitch 9900”
