Hi everyone,
we use Alcatels ALE 30H at our office. It has no bluetooth, but a USB-A-Port. Can i use this port with a cheap Bluetooth-Dongle and connect any Bluetooth-Headset with it?
Or are only "special" bluetooth-headsets with pre-connected bluetooth-dongles possible?
Thank you!
Peter from Germany
Connection of an ALE30H with a Bluetooth-Dongle
- frank
Re: Connection of an ALE30H with a Bluetooth-Dongle
Documentation says this:
Create, modify or consult your interphony list (max. 10 numbers)
Reach the 'Menu' page.
Settings My services Interphony
Enter your password.
Select an entry.
Follow the on-screen instructions.
Install a USB accessory (Headset, Handsfree, Loudspeaker)
Connect the accessory to the USB connector (USB-A, USB-C).
When you plug the accessory in the USB port, the USB accessory is automatically detected. If an another accessory is already connected with the same function, a popup asks you to select your preferred accessory to use for this function
I wish people read the documentation, instead of me having to do the work for them :/
Select an entry.
Hi Frank,
thank you for your answer.
I did read the manual of course, i just forgot to mention that.
By reading the manual, you could think, it works. But i think, alcatel wouldn´t let a 5-Euro-Dongle work on their phones, if they sell you the BT-Extention for about 80 Euro.
I thought to ask here if anybody has experience with a cheaper dongle, that works in that phone
