DHCP SNOOPING
mspdogomaha
DHCP SNOOPING
Post by mspdogomaha »
Hello
I am trying to set up DHCP snooping. I have read up on the doc and have come up with this config but the switch is not taking it.
ip helper dhcp-snooping enable
ip helper dhcp-snooping binding enable
ip helper dhcp-snooping ip-source-filter port 1/1/1-24 enable
ip helper dhcp-snooping port 1/1/25 trust
Re: DHCP SNOOPING
this are the commands for R6.
But here that ones for R8:
dhcp-snooping admin-state enable
dhcp-snooping binding persistency admin-state enable
dhcp-snooping ip-source-filter port 1/1/1-48 admin-state enable
dhcp-snooping linkagg 1 trust
mspdogomaha
Re: DHCP SNOOPING
I am not using linkagg so would i just apply the trust to the interface?
Re: DHCP SNOOPING
dhcp-snooping port x/x trust
Return to “OmniSwitch 6360”
