Notification Server Port number
pots
Post by pots »
Anybody know what port number is used for notification server signalling on the OXE? Can't find it in any of the doco's or the port number list spreadsheet.
Need it for a firewall config.
Thanks in advance.
Re: Notification Server Port number
In the system documentation, there is a file called IP Flow Extractor or something like that.
It list all ports of all applications.
pots
Post by pots »
Thanks Frank,
I have looked through that doco. Cant seem to find the port for notification server, but the old eyes are not what they were.
Anyway, think it uses port 1200 from some tcpdump traces and that seems to work.
Thanks for the response.
Andy Fitz
Return to “Notification Systems”
