OS6900-x48c6 transciever problem
qucent_
Post by qucent_ »
Hello, Engineers
There is currently a problem with the transceiver in OS6900-x48c6.
When insert Cisco's genuine UTP to SFP on the switch, it says not supported and is not recognized.
so, when I change the speed on the interface to 10G and then change it back to 1G, communication is normal,
but when I remove UTP, the link status is still up.
Trying to solve these problems
Regarding this, I would like to know if there is a hidden command such as a module recognition compatible command like Cisco.
Also, I would like to know what type of SFP is compatible.
I would appreciate your help.
Thank you.
Return to “OmniSwitch 6900”
