Disable TCP services on switch
kent2612
Post by kent2612 »
Hi, Please help as I need to disable TCP/101 below from running on the switch.
Product Category OMNISWITCH 6560
SW Release 8.8.R02
SW Version 8.8.56.R02
SW > show tcp ports
Local Address Local Port Remote Address Remote Port State
0.0.0.0 101 0.0.0.0 0 LISTEN
Re: Disable TCP services on switch
first update to the newest release. Maybe this was an bug....
kent2612
Post by kent2612 »
Any idea what is the supported command below?
SW > ip service port 101 admin-state disable
ERROR: Command no longer supported. Please use 'IP SERVICE <service name>' command.
SW > IP SERVICE ?
PORT SOURCE-IP TELNET SSH SNMP RADIUS NTP
HTTPS HTTP FTP ALL
(Miscellaneous Command Set)
I know only the predifined services like telnet, ssh...
Search in cli-guide or open a ticket.
BR Silvio
