Alcatel OS6360 & 6560 show anonymous UNP users
2502chakir2023_
Post by 2502chakir2023_ »
Hello everyone,
When authenticating devices via TEAP on the Alcatel switch OS6360-PH24, we do not see the correct username. When issuing a "show unp users" command, these devices display "anonymous" as the username (see attachment). However, the RADIUS server (ClearPass) does show the correct username. On older Alcatel switches (6450 & 6350), we do see the usernames correctly.
Anyone any idea where the problem could be related ?
It would look better if usernames were shown. also it would help for troubleshooting.
Kind regards,
Chakir
Re: Alcatel OS6360 & 6560 show anonymous UNP users
Maybe the reason is TEAP. With PEAP or tls it shows the correct username. If you already use the actual firmware than you should open a ticket at ALE.
BR Silvio
Return to “OmniSwitch 6450”
