question about interoperability of oaw ap
Also known as OmniAccess Instant AP
WallyGBR_83
Post by WallyGBR_83 »
hello all,
I would like to know if access points like ap12xx or ap13xx can work with the ap1101 ( that I already own ) configured in express mode,
more precisely if they can join the same ap group, id, management IP and if clients can roam between different ap models without losing network connection.
Re: question about interoperability of oaw ap
Yes, this is possible.
BR Silvio
WallyGBR_83
any of ap12 or ap13 series? as i have three ap1101 with one of them that, in the past, was not joining the group cause it was running an old firmware.
is there any compatibility table for reference?
You can use all stellar APs together in one cluster. Normaly it should work with different firmware too. Thats why there is no list about the interoperabily necessary.
But you are correct - sometimes it does not work. Than an update of all AP to the same newest release is helpfull.
BR Silvio
Cristek
Post by Cristek »
You can mix and match any Stellar AP models into the same cluster. Simply ensure you always use the latest version of firmware!
Return to “OmniAccess Wireless Access Points”
