remove lacp agg from configuration
shaifshahin
Post by shaifshahin »
I found this configuration on 6360, I need to remove this, though its disable now, but i need to remove it .
linkagg lacp agg 32 size 8 hash tunnel-protocol admin-state disable
linkagg lacp agg 32 name "Created by Auto-Fabric on Sat Aug 31 12:00:15 2024"
linkagg lacp port 1/1/10 actor admin-key 65535
when i tried to remove it from web interface, getting this error
Delete LACP Aggregate failed. 0: Submission failed : Aggregate has MVRP Config;
Re: remove lacp agg from configuration
the messages are clear.
First disable mvrp and auto-fabric.
Than delete LACP at port 1/1/10 and than the Aggregate 32.
best regards
Return to “OmniSwitch 6360”
