Add filters to an uplink port for internet provider
Reginaldo
Post by Reginaldo »
Can anyone tell me how to add filters to an uplink port for my internet provider, in order to block spanning tree BPDUs and the LLDP protocol?
For example, on Cisco switches, I already use the commands below:
no lldp transmit
spanning-tree portfast
spanning-tree bpdufilter enable
Cristek
Re: Add filters to an uplink port for internet provider
Post by Cristek »
I'm new here but I now know some of these as I had to learn them for our customers. The Network Configuration Guide describes all this in great detail.
You can mark a port into a predefined group and then tell the switch what to do if 'something' comes into this group. This 'something' can be:
bgp bpdu dhcp-server dns-reply dvmrp isis ospf pim rip spoof vrrp
So if you want to filter ospf traffic and shutdown the port for bpdu traffic:
policy port group UserPorts 1/1/1
qos user-port filter ospf user-port shutdown bpdu
qos apply
If shutting down the port, you'll also need this if you want unlimited auto-recoveries:
violation recovery-time 60
violation recovery-maximum infinite
By default the switch sends and receives LLDP packets. You can choose to only process received packets or disable them altogether:
lldp port 1/1/1 lldpdu rx
lldp port 1/1/1 lldpdu disable
Alcatel switches don't support CDP. Maybe you can create a policy to drop that specific type of packets (?). You'll have to investigate the options there.
Some of the more experienced guys will probably add a few bits and pieces to this :)
Hi Reginaldo,
do you whish to filter the outgoing or the incomming packets at your switch?
For the incomming you can use the userport feature - but I would in this case prefere to use all with filter (no shutdown). LLDP will not work for this. There you need your own policy with condition for destination mac of lldp and action deny.
For outgoing you can disable STP and LLDP at the port.
BR Silvio
Reginaldo
Post by Reginaldo »
Hi Silvio.
I believe that only for outgoing should solve the problem, because my concern is that the internet provider's equipment is not elected as a root bridge in spanning tree, so stopping sending BPDUs on this port should solve the problem.
As for LLDP, it also prevents third parties from identifying my equipment.
In the case of LLDP, I believe that using the command below should solve the problem:
lldp port 1/1/X lldpdu RX or Disable
But regarding spanning tree, is there an option to disable it per port on the 6560?
Thanks.
Cristek
Post by Cristek »
When I posted my examples, they were just a baseline for you to adapt. As per Silvio, shutting down an ISP port is not really a good idea.
You may or may not want to filter dhcp and/or bpdus from your ISP:
qos user-port filter bpdu dhcp
qos apply
Personally, I don't think disabling STP on that port is a good idea. Instead, you can prevent them from becoming the root bridge:
spantree cist port 1/1/1 root-guard enable
But if you really want to disable it altogether:
spantree cist port 1/1/1 disable
And if you want to be extra careful:
loopback-detection enable
loopback-detection port 1/1/1 enable
And you already know how to disable LLDP :)
But I can't help but notice that you seem to be focusing on Layer 2. Could you turn that port into an L3 port instead? Obviously you haven't given enough details so I'm just wondering!
Reginaldo
Post by Reginaldo »
Hi Cristek
Thank you for your help!
