Please Can any help me to configure xBS 8378 dect ip-xbs in my OXE , such is ths first time i would like to you use this type of DECT base .
IBS base is already insttalled in my OXE PBX
Best Regards
how to configure xBS 8378 dect ip-xb OXE
ACFE OXE R10
Re: how to configure xBS 8378 dect ip-xb OXE
There is a document on that, e.g. for R12.4 its "oxe12.4_sd_Mobility_8AL91009USAK_3_en.pdf" in System Documentation folder.
Check chapter 2.3 8378 DECT IP-xBS
If it's only one node and only XBS's are used then it's easy and straightforward configuration.
In theory PARI for every DECT system should be unique - You get it from ALU or your BP for your ordered DECT-system.
But in practice, you can configure any PARI number in the system.
