Multicast IPTV on 6360 freeze
jbm
Post by jbm »
In my IPTV infrastructure, I have configured several Alcatel switches to handle multicast traffic. The main switch is connected to an IPTV streamer, and the cascaded switches distribute the multicast streams to televisions. Here are the key points:
Current Configuration:
The switch with the streamer has multicast enabled and operates correctly. Features such as IGMP Snooping, Querier Forwarding, and Spoofing are configured.
The cascaded switches are also configured to handle multicast, with features like IGMP Snooping, Proxying, and Zapping enabled.
VLAN 12 is used for IPTV, and multicast routing appears to be properly set up.
Observed Issue:
When the TV is directly connected to the main switch with the streamer, IPTV streams work flawlessly.
However, when the TV is connected to a cascaded switch, the image frequently "freezes," leading to an unsatisfactory user experience.
Switch with streamer :
system name "Baie-Streamer"
configuration error-file-limit 2
interfaces 1/1/25 hybrid-mode copper
vlan 1 admin-state enable
vlan 12 admin-state enable
vlan 12 name "Wifi_TV"
vlan 111 admin-state enable
vlan 111 name "WifiPatiens"
vlan 999 admin-state enable
vlan 999 name "ADMIN"
vlan 1010 admin-state enable
vlan 1010 name "WifiTel"
vlan 12 members port 1/1/1-8 untagged
vlan 111 members port 1/1/15-16 untagged
vlan 999 members port 1/1/9-14 untagged
vlan 1010 members port 1/1/17-20 untagged
vlan 12 members port 1/1/21 tagged
vlan 12 members port 1/1/24-28 tagged
vlan 111 members port 1/1/21 tagged
vlan 111 members port 1/1/24-28 tagged
vlan 999 members port 1/1/21 tagged
vlan 999 members port 1/1/24-28 tagged
vlan 1010 members port 1/1/21 tagged
vlan 1010 members port 1/1/24-28 tagged
spantree vlan 1 admin-state enable
spantree vlan 12 admin-state enable
spantree vlan 111 admin-state enable
spantree vlan 999 admin-state enable
spantree vlan 1010 admin-state enable
ip interface "IPTV" address 192.168.16.252 mask 255.255.248.0 vlan 12 ifindex 1
ip interface "ADMIN" address 10.255.99.252 mask 255.255.255.0 vlan 999 ifindex 3
ip multicast admin-state enable
ip multicast querying enable
ip multicast spoofing enable
ip multicast zapping enable
ip multicast querier-forwarding enable
aaa authentication http "local"
aaa tacacs command-authorization disable
ntp server clock1.ovcirrus.com iburst
ntp server clock2.ovcirrus.com iburst
ntp server clock0.ovcirrus.com iburst
ntp server clock3.ovcirrus.com iburst
ntp client admin-state enable
lldp network-policy 1 application voice vlan 1010 l2-priority 5 dscp 46
lldp nearest-bridge chassis tlv management port-description enable system-name enable system-description enable
lldp nearest-bridge chassis tlv management management-address enable
lldp nearest-bridge chassis tlv med capability enable network-policy enable
lldp port 1/1/1 med network-policy 1
lldp port 1/1/2 med network-policy 1
lldp port 1/1/3 med network-policy 1
lldp port 1/1/4 med network-policy 1
lldp port 1/1/5 med network-policy 1
lldp port 1/1/6 med network-policy 1
lldp port 1/1/7 med network-policy 1
lldp port 1/1/8 med network-policy 1
lldp port 1/1/9 med network-policy 1
lldp port 1/1/10 med network-policy 1
lldp port 1/1/11 med network-policy 1
lldp port 1/1/12 med network-policy 1
lldp port 1/1/13 med network-policy 1
lldp port 1/1/14 med network-policy 1
lldp port 1/1/15 med network-policy 1
lldp port 1/1/16 med network-policy 1
lldp port 1/1/17 med network-policy 1
lldp port 1/1/18 med network-policy 1
lldp port 1/1/19 med network-policy 1
lldp port 1/1/20 med network-policy 1
lldp port 1/1/21 med network-policy 1
lldp port 1/1/22 med network-policy 1
lldp port 1/1/23 med network-policy 1
lldp port 1/1/24 med network-policy 1
health threshold memory 80
switch with TV :
system name "MedecinePolyvalente_2e_etage"
vlan 111 name "WifiPatients"
vlan 12 members port 1/1/1-4 untagged
vlan 12 members port 1/1/25-28 tagged
vlan 111 members port 1/1/25-28 tagged
vlan 999 members port 1/1/25-28 tagged
vlan 1010 members port 1/1/25-28 tagged
spantree mode flat
ip interface "ADMIN" address 10.255.99.238 mask 255.255.255.0 vlan 999 ifindex 2
ip multicast proxying enable
health threshold memory 90
auto-fabric admin-state disable
Cristek
Re: Multicast IPTV on 6360 freeze
Post by Cristek »
Did you try testing without ip multicast proxying enable in the second switch?
Which type of switch is the "cascaded switch"? Have you seen the same issue with SD instead of HD or 4K?
Return to “OmniSwitch 6360”
