4038 Stuck Keys
Jean0503
4038 Stuck Keys
Post by Jean0503 »
A user has an error displayed on his Iptouch 4038. It says "Stuck keys: [Volume_Inc][Mute][Release][Enter]5Backspace]"
This message appears even after rebooting.
The phone worked correctly for years. No change was made on the OXE, and I checked that it was not locked.
I can't operate this device myself cause it's on a remote site. But the user can if I ask him :-)
What can I do to remove the message ?
Thanks.
Re: 4038 Stuck Keys
Some key on set pressed all time.
Jean0503
Re: 4038 Stuck Keys
Post by Jean0503 »
the user says "no key stuck".
Re: 4038 Stuck Keys
Maybe someone cleaned the set, used some type of solvent and got the electronic stuck.
4038 are pretty old...
