alcatel 8068s Duplicate ip
IP and Voice over IP
dmytro
Post by dmytro »
Can anyone help? There is an error with an internal conflict of ip addresses "Duplicate ip". Maybe there is a solution to this problem or firmware for USB recovery. The phone does not respond to buttons and is stuck on boot Stage 1. Thanks.
Re: alcatel 8068s Duplicate ip
If you have duplicated IP - change IP address of the phone (this address already used)
dmytro
Post by dmytro »
vad wrote: 09 Mar 2025 23:30 If you have duplicated IP - change IP address of the phone (this address already used)
Ok, thank you. Everything worked out. True, not the first time.
Return to “IP / VoIP”
