termstat showing PIN
Locked
tomekandos
Post by tomekandos »
I have R101. When I used older version of termstat gave me possibility to check PIN.
In current version it is ****.
Is there any other way to check PIN?
Kind regards
Re: termstat showing PIN
There was a request to mask the PIN as part of the security feature delivered from n2 MD6.
Therefore, you can't see it anymore.
tomekandos
I was afraid to here that answer.
Thank you.
But why - afraid?
You can't see. But you can change PIN (mgr or NMS).
Locked
Return to “MAIN”
