8158s and wlan search
tom1168
Post by tom1168 »
Hi , my Problem i will use the 8158s in uibiquity wifi with an auerswald system as a sip phone is this possible. The Phone show me nothing after searching the wifi. Thank for answer.
Re: 8158s and wlan search
For the 8158S, you need to use WinPDM Software in order to setup the features you want for the WiFi
Return to “SIP Extension”
