Can't login to os6450
denrode69
Post by denrode69 »
Hello team,
Im pretty new with alcatel and noticed that after booting up it got stuck and I'm not able to type anything
CMM-NI IPC blocked - EOIC Not Recvd
login :
Successfully sent the I2C read message to NISUP!!
Dragonite FW Version: Mar 12 2012 08:58:56 Ver 1.4872
Hope you can help me
Re: Can't login to os6450
I think this isn't a alcatel issue. Probably you have a problem with your serial connection. Try other settings for the flow control there.
BR Silvio
Return to “OmniSwitch 6450”
