hello,
i have been trying to replace my faulty IVU with new one,
i have replaced the new MAC address under tscip but error message is appearing " object -1: terminal ethernet address: invalid attrib value"
what would be the issue?
thanks!
Replacing MAC Address error
- frank
Re: Replacing MAC Address error
Are you copying / pasting the MAC address?
Did you try checkdb to validate the database?
Hi frank
I have tried to manually adding through omnivista and also from the terminal both giving the same error
- frank
Are you sure the set is set as an IP set or SIP?
What does the CheckDB Show?
Did you try to delete the extension and re-create it?
yes its an IP set,
i have tried to delete the extension, but its was giving me error i cannot delete it "set unavailable or operator in a bad state"
- frank
what type of extension is it? Call center? Operator?
Yes it is a call center, main lines and linked to several ext.
- frank
You need to remove this set from being an agent most likely . make sure it is logged off. then remove the agent feature. I think. but something like that.
