6850-48 Couldn't boot finished ~~need help!!
wisdompin
Post by wisdompin »
Dear everyone
I had do restore password on one 6850-48 switch.
I deleted usertable4 file successfully.
When I reboot it , I got below information and it clouldn't boot finished
Have anybady could help me?
U-Boot 1.1.0(6.1.3.601.R01) (Sep 13 2006 - 14:37:19)
MPC8248 Reset Status: External Soft, External Hard
MPC8248 Clock Configuration
- Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq 25-75 , Core Freq 100-300
- dfbrg 0, corecnf 0x1a, busdf 3, cpmdf 1, plldf 0, pllmf 3
- vco_out 400000000, scc_clk 100000000, brg_clk 100000000
- cpu_clk 400000000, cpm_clk 200000000, bus_clk 100000000
- pci_clk 66666666
CPU: MPC8248 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz
Board: Alcatel OS68xx (Kite II)
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
Device 0: Model: SanDisk SDCFJ-64 Firm: HDX 2.33 Ser#: 012003C2006U0107
Type: Removable Hard Disk
Capacity: 61.2 MB = 0.0 GB (125440 x 512)
USB: scanning bus for devices...
USB device not responding, giving up (status=80000000)
0 USB Devices found
Hit any key to stop autoboot: 0
## Booting image at ff900000 ...
Image Name: miniboot-6.1.3.601.R01
Image Type: PowerPC VxWorks Kernel Image (gzip compressed)
Data Size: 781716 Bytes = 763.4 kB
Load Address: 00005000
Entry Point: 00005000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
## Ethernet MAC address not copied to NV RAM
Loading .text @ 0x01000000 (1203372 bytes)
Loading .rodata @ 0x01125cb0 (242483 bytes)
Loading .data @ 0x01160fe8 (109988 bytes)
Clearing .sbss @ 0x0117bd90 (1556 bytes)
Clearing .bss @ 0x0117d000 (1818940 bytes)
## Using bootline (@ 0x4200): flash(1,0)cmm:default h=192.168.10.1 e=192.168.10.1:ffffff00 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff f=0x0
## Starting vxWorks at 0x01000000 ...
ataDrv call. 0 1 24 24 621 0 0
CS EEPROM Module ID: 42012216 , System type: 48 port 1000Base-T, with 4 combo ports, stacking - kite2
Adding 4804 symbols for standalone.
Boot parameters are:
'flash(1,0)cmm:default e=10.255.24.81:ff000000 h=192.168.10.1 g=10.255.24.181 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS miniboot version: 6.1.3.601.R01
VxWorks (for Alcatel CMM MPC8248) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on Sep 13 2006, 14:39:14.
Copyright Wind River Systems, Inc., 1984-2006
CPU: Alcatel CMM MPC8248. Processor #0.
Memory Size: 0xfa00000 (250 MB). BSP version 1.2/1.
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2006. All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. All Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/K2os.img'...
5365776
Loaded 'alcatelNetworking_kernel.lnk' from '/flash/certified/K2os.img'.
Starting at 0x100000...
Adding 9877 symbols for standalone.
AOS kernel version: 6.1.3.719.R01
Made on Dec 6 2006, 18:54:49.
0xf9ffde8 (tRootTask): cmm_random_init OK
0xefb44a8 (tWhirlpool): batch_entropy_process called
Target Name: vxTarget
User: target
Attaching network interface lo0... done.
The current date and time is:
Coordinated Universal Time (UTC): TUE JAN 08 00:44:23 2008
Local time: TUE JAN 08 08:44:23 2008 LOCAL
Starting dynamic software load from '/flash/certified/'...
Creating archive cache...
unable to load Stack Manager Library - ABORT! <===== it stop on here
Thanks!!!
benny
Re: 6850-48 Couldn't boot finished ~~need help!!
Post by benny »
I never saw this error message yet. Are you sure that you have all the necessary images in the /flash/certified directory? Did you maybe interrupt a certify process by rebooting the switch?
Please post the output of "fatls" for the /flash/working and /flash/certified directory from u-boot command shell.
Thanks,
Benny
