Switch from Instant Communicator OTUC to Teamwork
Hi guys,
Well this application on its OTUC behaviour is nothing else than a 4980 with skin modified. Can't find something that an already 4980 installed can do, the only advantage I can see is that license consumed is not 4980 so you can use this more wisely for users who really need all power.
For TW is only a switch from web to an exe, so if you are not a web lover you can use this.
Now what I found is that there is no easy way to switch from one mode to another. Why? No idea.
So i investigated a little bit and found the how to, really easy (for people with PC knowledge)
So here is the how:
Open your regedit
go to HKEY_LOCAL_MACHINE\Software\Alcatel\MPC\Server
Here:
Configuration and Location keys are what we need:
For OTUC:
Configuration = FullUC
Port = 443
Location = otuc.yourdomain.com
For TW:
Configuration = MyTeamwork
Port = 443
Location = teamwork.yourdomain.com
Enjoy :D
I'll do an EXE to do the task more easy later
Return to “MyIC (My Instant Communicator)”
