DISA Usage
knightr1der
DISA Usage
Post by knightr1der »
Can anyone advise me whether youcan make more than one call once you have accessed DISA service without hanging up and dialling in to DISA again?
tia..
siti
Re: DISA Usage
Post by siti »
Yes. The maximum simultaneous calls I have proven is 3. I haven't tried the fourth call so I cannot give a specific answer as to the maximum simultaneous calls that can be made.
Hope this helps.
Cheers
Siti
There is no lift to success.You have to take the stairs - one at a time.
knightr1der
Re: DISA Usage
OK, so if you dial in to DISA service and make 1 call to an internal user, then you want to make another call to an external number after you have finished with internal call - how do you make the new call without hanging up and dialling in again?
siti
Re: DISA Usage
Post by siti »
Im sorry Knightrider. I interpreted your first question wrongly.
I thought you wanted to know the maximum number of simultaneous calls through DISA.
Sorry about that.
knightr1der
Re: DISA Usage
siti wrote:Im sorry Knightrider. I interpreted your first question wrongly.
Sorry about that.
Hey - no problem siti.
I do not think it is possible (what I am asking for). Even a normal user on OXE has to terminate call to establish new call. So I think external caller using DISA must terminate call and re-connect to OXE via DISA for new call :?
Re: DISA Usage
Yeah, how would OXE do something, maybe a suffix that can be used during a call....but don't think so.
Re: DISA Usage
Don't think you can do that. But with integrated cellular client you can. You can set up suffixes used by cell phone 1 let's say for consultation call ( See SysDOC-->OmniMobility-->OmniPCX integrated Cellular Client--->Servces provided)
So: for limited number of users + licences :(
Regards.
Return to “MAIN”
