ringing in Operator
morad
ringing in Operator
Post by morad »
hi,
i am using oxo R4 and another R6, but the customer need when the operator is busy and the extension call to the operater in the same time he want him to heard normal ringing (like when he don't busy) not beeb beeb
can anyone help me
aflores
Re: ringing in Operator
Post by aflores »
Have you check, How many General Resourses Keys, that the attendant have?
All my systems, to the operator, I programm almost 3 or 4 General Resourses Keys (Incoming-Outgoing / Internal-External) and never have this trouble.
Hope y help
Regards.
AFLORES
morad
Post by morad »
I try to do this before, but nothing happened................
Schappe_DUP
Post by Schappe_DUP »
Hello.
If you still have this problem, look under Feature Design / Part 1 and make sure "Busy attendant Indication" is not marked.
Best regards Peter
morad
Post by morad »
I check but there is no marking...
Return to “MAIN”
