MIPT 310
benny
Re: MIPT 310
I am not good in VoWLAN stuff but you will have to check the basic connectivity between the devices. Where is the tftp server - is it reachable by other devices? Is the VoWLAN phone associated with the good SSID?
rovello.razon
Re: MIPT 310
Thanks for your reply. The 310 set can detect the AP so i assume it is connected. The tftp server is the PBX and all IP phones work using the TFTP address. The SSID is already assigned.
benny
Re: MIPT 310
Can you ping the VoWLAN phone from the controller?
Is the PBX in another vlan? Do you have the right gateway IP on the VoWLAN phone?
rovello.razon
Re: MIPT 310
Yes I can ping the 310 handset but only for a while, after that it initializes again. It is connected to a vlan same with the IP phone which are working fine. the gateway is also the same as with the IP phone
Donnobo_DUP
Re: MIPT 310
Does it initialize all the time? Set MIPTUser-> Reset for Update authorized to 0. And try again. It wont reset anymore (for update).
- Krusty65
Re: MIPT 310
waqasrehman_DUP
Re: MIPT 310
Can u check if u have enabled Security in your MIPT 310
If is checked then uncheck it any then try it
Waqas
Waqas
rovello.razon
Re: MIPT 310
The security is checked and then unchecked but still the same. by the way I do not use the SVP server
Where is that command MIPTUser Im am using OXE
feddy006
Re: MIPT 310
Please check what role it falls in the Controller by using the command # show user if it is still on logon role then we have identified the problem. Try giving the initial role aas Authenticated if mac and .1X is not being used.
Hope this helps....
Hope this helps....
