What is the OXO SMDR IP port for a Hyper Terminal connection
ckoz
What is the IP port for the OXO system to allow a HyperTerminal connection connect and receive call accounting data?
tuxalize
Re: What is the OXO SMDR IP port for a Hyper Terminal connection
No.
Since OXO R5, we are able to get Metering Tickets by IP, but OXO sends the information in XML file.
We have to install the OLD (OmniPCX Office Link Driver), that is free, in a PC and this OLD will rescue the XML files and save in this PC.
Note: the Metering Tickets by IP needs license. (it is on ACTIS).
Tux
Tux
nillok
I have a license "Call accounting over IP". Wich port can i connect to collect SMDR?
krzysioD
I think that you need to
a) instal OLD on PC
b) use some webservice to get data
c) read doc's everything is described there.
a) instal OLD on PC
tuxalize
Just install the OLD on PC at the same network as OXO.
Follow the initial instruction of OLD to put the OXO IP address.
Then the xml file will be stored under programs files/...... where the OLD is installed
You can open it using Excel.
Enjoy.
Tux
Enjoy.
Tux
