Using IMAP on 4635
Locked
jbower
Using IMAP on 4635
Post by jbower »
Is it necessary to use a seperate appliance server to support 10 IMAP licensces used to record voice and send an email pop of it. I intend on using it to record hour long conversations that will be sent to an email account that will be burned to a cd and then erased. I was under the impression when I got my AQPS cert a few years ago it could support 100 IMAP license on a 4635 voice mail system which we are using. The BP which we purchased these license from says that 4635 is not robust enough to handle what i intend to use this for. My system has (3) SPA 3 boards and (1) MSBI board. They also claim that this feature only works some of the times. Any input would be appreciated.
elcoma7
Re: Using IMAP on 4635
Post by elcoma7 »
the documentation said if you have less than 100 IMAP license,you can share the server for IMAP and Voice mail Application.
but if you want to record conversation for long hour...it is better if you use voice logger, as it is designed to record conversation.
Locked
Return to “Voicemail (46x5)”
