I need to download the call tickets from the OXE.
Where are they?
thanks
Where are the call tickets?
gper
gper
doddykartiwa
use this command:
> accview -tf TAXA***.DAT > xxx.txt
that command will convert the .DAT file into readable file titled xxx.dat which will be in /usr2/mtcl folder (local folder of mtcl user, you should be in that folder when you ftp/telnet in). then simply ftp that file, and read it with your word processing application
Re: Where are the call tickets?
hello everybody
someone know how i can send taxa file by mail for all users on OXE and OT.
Or indicate the configuration procedure
