Inserting OPS
thatawa
Inserting OPS
I've just installed R8.0.1 g1.503.12.a and it work fine.
But i usually transfer OPS by FTP, so i start FileZilla and connect to my Virtual Machine but the connection is released by remote host (Virtual Machine).
So, how you transfer your OPS ??
Thank you.
Thank you.
Re: Inserting OPS
just in same way, did you enabled security in OXE? If so you need to disable or use secure FTP
stefan
Re: Inserting OPS
try the gkermit (to transmit files in binairy mode using X-modem protocol (on V24)) command, I sometime use it when FTP connection is not available...
thatawa
Re: Inserting OPS
@ cavagnaro :
I did not enabled security when installing th version.
@ stefan :
I was thinking about this way, but i would like to know why the connection is closed.
I've tried why FIlezilla, FTPexpert, and with other software but the result is still the same.
I've even tried in MS-DOS commands then, i'm connected 1 or 2 seconds ans the connection is released by host.
If you have any ideas...
@ stefan :
thatawa
Re: Inserting OPS
This is what happen with MS-DOS commands :
ftp> open 192.168.1.201
Connecté à 192.168.1.201
Connexion fermée par l'hôte distant.
ftp>
I am connected while 1 or 2 seconds then connection is closed.
ftp>
Re: Inserting OPS
Do the following and this is what you should get:
(101)xa001001> netstat -ln |grep 21
tcp 0 0 0.0.0.0:4021 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:21 0.0.0.0:* LISTEN
thatawa
Re: Inserting OPS
This is what i get :
(1)xa000001> netstat
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 loopback:10004 loopback:cmisd ESTABLISHED
tcp 0 0 loopback:cmisd loopback:10004 ESTABLISHED
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node Path
unix 11 [ ] DGRAM 1378 /dev/log
unix 2 [ ] DGRAM 37414
unix 2 [ ] DGRAM 36198
unix 2 [ ] DGRAM 24997
unix 2 [ ] DGRAM 5715
unix 2 [ ] DGRAM 5714
unix 2 [ ] DGRAM 2031
unix 2 [ ] DGRAM 1869
unix 2 [ ] DGRAM 1527
unix 2 [ ] DGRAM 1518
unix 2 [ ] STREAM CONNECTED 704
(1)xa000001>
So i can see the port 21 is not listenning.... how can i configure it to listen to connections ?
thanks
(1)xa000001>
thanks
thatawa
Re: Inserting OPS
Ho sorry !!!!!! I thought it was the same .
This is what i get
(1)xa000001> netstat -ln |grep 21
(1)xa000001>
thx
This is what i get
(1)xa000001>
thx
