I've found information about OXE--Fidelio Opera and Fidelio Suite but nothing about Xpress (V3.0).
According to PMS vendor Xpress is a limited version of Opera's
You can use internal accounting and send cost directly to Fidelio.MTConsulting wrote:Have got it working, 'maid status' and 'call accounting' DONT work as Fidelio looks for meter pulses, everything else worked.
Maid Status will work when you can see it on a 4090 Add-on, with a key for each room set up on it.
tot3nkopf wrote:You can use internal accounting and send cost directly to Fidelio.MTConsulting wrote:Have got it working, 'maid status' and 'call accounting' DONT work as Fidelio looks for meter pulses, everything else worked.
