Any knows how to ftp a 6850
Yanesh
Post by Yanesh »
Can someone tell me the procedure how to FTP a 6850
benny
Re: Any knows how to ftp a 6850
Post by benny »
Could you let me know what exactly was unclear with the description in your other topic at:
viewtopic.php?f=86&t=5609
What about searching Google for basic FTP operations?
-benny
Yanesh
Post by Yanesh »
Hi benny i FTP switch using filezilla but i am getting this error; can you advise please
Command: CWD /flash:
Response: 501 Directory non existent or syntax error
Error: Failed to retrieve directory listing
Status: Retrieving directory listing...
Command: CWD /
benny
Post by benny »
Don't use the FileZilla FTP Client.
Use the ftp.exe of your Windows and do it manually.
Benny
raven22
Post by raven22 »
Hi!
I usually use TotalCommander's built in FTP client, but before use you should set up the right mask to display the directory and files information (the default mask doesn't suit). And also you should set up the aaa authentication for FTP (and enable FTP service :-)).
