SIP TRUNK
If you wrote a good one, share it with us !
talkhalidi
SIP TRUNK
Post by talkhalidi »
Hi All,
i have setup SIP trunk with Avaya system. i just cannot call Avaya extensions from Alcatel IP Phone. once called the number i get congestion and as per traces on Avaya , the call did not land on the trunk group of Avaya.
i have setup the routing plan and prefix plan as follow
57
route number
trunk group sip 2
subnet network 2
please tell me how i can trace the call made by Alcatel Phone on alcatel system ? how do i setup the dial plan ?
once i
Re: SIP TRUNK
Please read the documentation, all your questions are detailed in there.
talkhalidi
Re: SIP TRUNK
ok fine my dear i dont mind i have been looking in the document, actually the structure of document not that good. comparing Cisco and avaya Docs which is give you over all how to administer Dail PLan , then ARS , fAC.
i have followed an Example in document to setup the trunking between the 2 system , and again it did not work.
could you direct me where in document show you how to setup dial plan for whole system . normally as telecom i need the following
-1 define extensions range
2- define group extenion range
3- feature codes
4- ars list
5- AAR range
im not intrested to know now the ARS server if i have multiple alcatel nodes, in simple i want to setup the PBX later on i want to go into details and features.
how i can trace the call made by the phone? and how i can capture the SIP log please? i have been stuggle looking into document since 1 week and no luck to make the trunk call the other side.
root
Re: SIP TRUNK
Post by root »
talkhalidi wrote:Hi All,
57
route number
trunk group sip 2
subnet network 2
once i
poste your config and we could have a look
talkhalidi
Re: SIP TRUNK
ok here the config below
OXE IP = 192.168.254.240
AVAya IP = 192.168.254.200
SIP Trunk 1 = OXE, Subnet work 1 = OXE
SIP Trunk 2 = Avaya , Subnetwork 2 = Avaya
OXE users Extensions 201, 203, 2xx range
Avaya Extensions range 5702 ,6101 , 6xxxx range
i have configured prefix plan for 57xx , 6xxx to be 2 subnetwork, trunk 2, 4 digits.
below the trace for call trial made from extension 201 on OXE to avaya extensions 6101 . please find attached SIP trace
talkhalidi
Re: SIP TRUNK
i have posted the config and traces , however, it seems that it takes 2 days here to approve or not approve the post?!!!!
where is the admin for this forum?
Re: SIP TRUNK
In holidays...are you happy master?
Re: SIP TRUNK
talkhalidi wrote:ok here the config below
You are receiving error 488, check the codecs on both sides.
root
Re: SIP TRUNK
Post by root »
Your problem is in the OXE config part, the trace show that the OXE send the INVITE to
the OXE itself and response 488.
Please post following config snips (copy/paste from mgr)
- content of routing no. 6xxx
- content of network routing table 2
- content of sip ext. gateway 2
talkhalidi
Re: SIP TRUNK
thanks ,
i have attached the configuration of OXE. please note that the IP address for OXE is 192.168.254.240 , AVAYA 192.168.254.200.
am stuck since one week and couldnot find clue for my proble. appreciate your help guys.
Return to “Documentation”
