Active Call List
Fatma
Active Call List
Post by Fatma »
How can I see active call list by using XML Api services?
Best Regards,
Fatma
Re: Active Call List
What is a call list for you?
Fatma
Post by Fatma »
A call list shows all internal calls, external in and out calls. This call list shows calls' durations, status and all information about the calls.
Thank you,
Fatma
The log of calls that MyPhone builds? It is a DB query, I don't think that is accesible using XML API...what documentation says? Will try to give it a look this week.
Return to “XML Presentation Server & TAPI Server”
