Hi gurus,
the IP phones no longer working after restarting the oxe, i get message on the display tftp server error?
any idea what is the problem. network connectivity is fine between the phones and OXE
tftp server error
Re: tftp server error
what does this post have to do with documentation???
Are your phone Dynamic or Static??? You need to provide alot more info if you want our help....!!!!!!!!!
talkhalidi
well its static , i can pin the IP phone from the OXE. also i have verfied the lanpbxbuild .
Please next time take the time to post in right section.
Moving.
Moving.
Are your phones connected to a VLAN??? have you checked that the tftp address is correct in the phone. Are you using duplication?? and maybe you are points to the cpu addresses not the role??? Can you log in as root and complete a capture and post here
talkhalidi
i dont have duplication, its single CPU. i was trying to understand the role addressing. is the CPU address is the same as the role addressing? or there should be 2 different IP address for oxe one for CPU and one for role addressing? the role addressing is the TFTP address? . i can ping the phone from OXE there are on the same VLAN and the phone was working pervoiusly?
So there have been changes after all. What did you do while doing that reset?
