hI,
pLS HELP- I have a OXE which worked fine but suddenly it refuses
to connect client phones.
For configuration, the 4760 can not connect : CMISE error synchronisation
Telnet works but list command does not work. error loading shared libraries.
Any ideas.
oxe- ALMOST DEAD
NADMIN
DB checkout
When I get in the system by telnet and run any commands like list it says libraries not loaded.
Please advice on how to run some common database checks.
It refuses to run backup through the 4760 and of course it refuses to connect.
Thanks,
Thanks,
- frank
Do you have anything in
/usr2/oneshot
/usr2/servers
/DHS3data/mao
Go to /DHS3data/mao (using ftp) and save hardware.mao and software.mao
Go to /usr4/BACKUP/ and see if you have anything in the folder DAY or DAY-1 , DAY-2 ... You should save all of it
Go to /usr4/BACKUP/OPS and save all the files too
Where are you located ?
/usr2/oneshot
/usr2/servers
/DHS3data/mao
