AHL Interface
midasman
AHL Interface
Post by midasman »
Can anyone send me the latest Hotel AHL interface spec for OmniPCX Version 9 ? I think it may be Version 4.5.2.1
Re: AHL Interface
Search in the BPWS
afeef
AHL Interface
Post by afeef »
hi
I have checked BPWS software download section couldn't find the software.
meynardp
Re: AHL Interface
Post by meynardp »
Hi All,
I'm developing a small application which I would like to integrate to OmniPCX Office, as I understand the application should communicate with the OLD application which is the one communicates with OXO. Do I communicate with OLD like in OXE? or it is totally different. How about the messages format?
Thanks.
et
Re: AHL Interface
Post by et »
meynardp wrote:Hi All,
I think, it is different. Example of file, generated by OLD, see in attach.
meynardp
Re: AHL Interface
Post by meynardp »
I see, do I have to read this file being generated by OLD from time to time?
Thanks.
et
Re: AHL Interface
Post by et »
TicketCollector.xml is a current file. After one hour or about that, OLD generates file with Name = Date&Time.xml. After that, the file TicketCollector.xml will be empty. From time to time OLD connectcs to OXO and retrieve tickets from OXO to TicketCollector.xml. I think, that you must read files with names Date&Time.xml.
meynardp
Re: AHL Interface
Post by meynardp »
Thank you et. How about for hotel functionalities?
Thank you so much.
et
Re: AHL Interface
Post by et »
I think, Hotel mode is different. If you have test OXO, you can make some tests. Switch OXO in Hotel mode, install OLD in Hotel mode and make traces. May be, you can find something useful in docs:
http://alcatelunleashed.com/viewtopic.php?f=65&t=3175
and topics:
http://alcatelunleashed.com/viewtopic.p ... D&start=10
http://alcatelunleashed.com/viewtopic.p ... &hilit=OLD
meynardp
Re: AHL Interface
Post by meynardp »
Thank you et. I'll check on this.
Thanks.
Return to “Hotel mode”
