Hai,
We are trying sip connectivity between OXE and Nortel.I am able to call from OXE to nortel but we nortrel tries to call OXE its not happing.OXE version is 8 and Nortel pbx is CS1000.
I tried with all possible codecs but the its not working. The nortel has generated the following report we they tried to call OXE
Nortel SIP trace report
oam> 13/02/2009 17:53:36 LOG0006 SIPNPM: SIPCallTrace: This is Outgoing Message
Message: Outgoing method INVITE(0) chid: 24 Called num: 7980 Far End Signaling IP: 10.10.3.5:5060 Transport:UDP CSeq: 1 INVITE
From: <sip:5028;phone-context=cdp.udp.com@ubmail.com;user=phone>
To: <sip:7980;phone-context=cdp.udp.com@ubmail.com;user=phone>
User-Agent: Nortel CS1000 SIP GW release_5.0 version_sse-5.00.31
Media Info: 10.10.3.78 Codecs: G729(18) G711 A-Law(8) G711 U-Law(0) Dynamic(111) Payload: 0 ms Media State: SIPNPM_MEDIA_SENDRECV
13/02/2009 17:53:36 LOG0006 SIPNPM: SIPCallTrace: This is Incoming Message
Message: Incoming response 302 Moved Temporarily chid: 24 Called num: 7980 Far End Signaling IP: 192.77.110.15:5060 Transport:UDP CSeq: 1 INVITE
Contact: <sip:7980;phone-context=cdp.udp.com@ubmail.com:5060;maddr=192.77.110.15;transport=tcp;user=phone;x-nt-redirect=redirect-server>
Message: Outgoing method ACK(1) chid: 24 Called num: 7980 Far End Signaling IP: 10.10.3.5:5060 Transport:UDP CSeq: 1 ACK
Message: Outgoing method INVITE(0) chid: 24 Called num: 7980 Far End Signaling IP: 192.77.110.15:5060 Transport:TCP CSeq: 1 INVITE
Message: Incoming response 100 Trying chid: 24 Called num: 7980 Far End Signaling IP: 192.77.110.15:5060 Transport:TCP
Pls help in this regard.The same problem occurred with OXO and Nortel
SIP: Is"Phone-Context" supported by OXE ?
samuel.aflalo
Re: Pls Help.....urgent!!!
If "To: <sip:7980;phone-context=cdp.udp.com@ubmail.com;user=phone>" is the to field in the invite message, the OXE will not be able to recognize it.
It should be standart an look like :
INVITE sip:39988783@10.7.0.74 SIP/2.0
Via: SIP/2.0/UDP 10.7.0.65:5060;branch=z9hG4bKjof5m000b8212do5c4s1.1
From: "39988784 39988784"<sip:039988784@172.16.60.1;user=phone>;tag=282290078-1229855627191-
To: "39988783 39988783"<sip:39988783@172.16.60.1>
Call-ID: BW123347191211208206535576@172.16.60.1
CSeq: 747490268 INVITE
Contact: <sip:039988784@10.7.0.65:5060;transport=udp>
P-Asserted-Identity: "39988784 39988784"<sip:039988784@172.16.60.1;user=phone>
You should generate OXE SIP traces and analyse them.
to run the OXE SIP traces, please type :
motortrace 3 (enter)
traced (enter)
capture all the traces in a file and analyse.
Good luck
traced (enter)
Good luck
knightr1der
another post with a very bad heading. This post will be re-titled in the next few days if no-one has any objection!
root
OXE does NOT support "phone-context", you have to open a marketing request
if you want the it will be developed
It was already discused here in the forum, use the search function.
But If I remember correctly Nortel has a patch available to deactivate "phone-context" on CS1K
Cheers,
root
Cheers,
root
