4635 do not create voice mail for Guests
alliance
Post by alliance »
Im facing a big issue on an OXE R8 in Hotel mode- 4635 is working for admin users but for guests.
When doing check-in the parameters for vmail is changing but it is not creating the voice mail in the 4635.
Have someone ever face this problem and can help me.
thks
Re: 4635 do not create voice mail for Guests
Detail your configuration and the way in which you assign VM to a room: AHL, hotmenu, manual?
Did you try to see if using hotmenu or manual from mgr you have same problem?
oldboy
Post by oldboy »
Have you entered the guest Voicemail MCDU under hotel????
alliance
Post by alliance »
I have done the creation by checking a guest through both hotmenu and AHL link.
But when i look at the mailbox in the 4635 console, it says it is not a valid mailbox.
I have put voice mail in MDCU under hotel.
abs_srinivasan
Post by abs_srinivasan »
My name is Srinivasan......
i have facing same issue for one of my customer any one help for the same......
Return to “Voicemail (46x5)”
