Good Day!
I have 3 OXOs interconnected and each OXO has analog trunk connected to it. I can access the analog trunk from another OXO. My problem is, the period of waiting for the connection takes around 25 sec. before I can hear a ringback tone. How can I shortened the time of connection?
Anybody help...
Access time for Analog Trunk from another OXO
Re: Access time for Analog Trunk from another OXO
Analog trunk with MF dialing or decadic?
End of dialing table managed or not?
tsunami
Thanks for the reply...
Yes it does. However, I still do not know how to managed the end of dialing table. Can you give me a hint on what to do, please...
What type of connection between OXO? F.e. if you use IP - VoIP/ VoIP parameters - you have item "End of dialing table used".
Numbering/ end of dialing table - manage number of digits.
- tot3nkopf
Do you have CLIP enabled on the trunk? Extension on the other OXO has z-clip enabled (set class)? Try to disable clip and see what happens.
Regards.
Regards.
