ALCATEL SIMULATOR ???
If you wrote a good one, share it with us !
athos19
Post by athos19 »
iv been working with alcatel product for early years
but for pre-configuration of my systems
i would like to know if there's any simulator
of alcatel pruduct like Packet tracer for cisco products
thank you all
Re: ALCATEL SIMULATOR ???
Check VmWare topics.
knightr1der
Post by knightr1der »
VMware
PBX Simulation on VmWare
It's a bit of a giveaway really!!!
athos19
Post by athos19 »
Thx i'm going to have look at it
athos19
Post by athos19 »
which version of VmWare should i buy exactly,
and can it simulate too the OTUC ?????(OmniTouch Unified comm),
thx alot
We used VMWare workstation for OXE, for OTUC you can use it but be aware that features like TTS will not work correctly as CPU usage is higher and has been built to use specific CPU features that a VMWare can't provide, that is why if you want full OTUC (no teamwork) you better buy a midsize server. TW can only be run on a real CPU, no VM at all.
athos19
Post by athos19 »
thank u'all
Return to “Documentation”
