My question to all.
Can we have a networking between OXO and OXE? if yes may I have some write on this.
Vasant
Networking of OXO and OXE
freedom
As far as I know it is not possible to make a network with OXE and OXO.
At least not an ABC network.
It is possible to create some kind of network by using the ARS. Than it is possible to dial "internal" numbers and translate them to the full DID numbers without the caller knowing it.
It is possible to do management with only one 4760 for both OXE and OXO.
Richard
Richard
Vnbadiger
networking of OXE and OXO
I like to say that you can do networking done between 2 system
i.e VoIP calls using ARS and Abb. dialing.. using IP trunks. It wont give you all feature of ABC-F but you can have conf and tranfers, basic feature working tired and working.
kleva
Networking OXO & OXE
Most definately YES!
Not an ABC-F (since this is only supported by OXE/4400), but a great deal of QSig functionality can be offerred between the two types of systems. You can do this with many type of trunk connectivity, but normally IP in the countries where bandwidth costs are affordable (or LAN connected).
I will look for the relevant docs (I have them), but want to know which method you intend on using, how many systems of each type and the software versions on each (since there are some issues between various versions, especially on IP and DLT cards). Please also specify whether using Common Hardware or Crystal Hardware on the OXE.
Oh, are you looking to actually configure this, or do you want info on the feature transparency only?
Cheers for now, KLEVA.
