fatal error - cfg handler
horak
Post by horak »
Hi guys,
I have a problem. I'm trying to run PR server at Virtual PC 2007 with Windows server 2008, but it doesn't works. I got a trial version of the licence key and set up the right values, but at the log is showing that fatal error:
17/05 23:35:17,915 INFO prs.alarm - PRS version 2.1.0.3.1-147
17/05 23:35:18,142 WARN prs.alarm - 0002 - ---- - ----- (0xFFFFFFFFFFFFFFFF,-1) - : Presentation Server Starting
17/05 23:35:18,597 INFO prs.monitor.events - The monitor has been started, listening on port 2009, authentication account 'api_support'
17/05 23:35:59,164 WARN prs.alarm - 0003 - ---- - ----- (0xFFFFFFFFFFFFFFFF,-1) - : Presentation Server Started
17/05 23:36:29,436 FATAL prs.system - Thread '[cfgHandler]' overrun the maximum processing time for consumer!
ConfigHandler ()
Config Handler
17/05 23:36:29,467 WARN prs.alarm - Presentation Server stops on error
Have anybody idea how can I fix it? Is necessary to config something else?
Re: fatal error - cfg handler
PRS can´t be installed on a virtual enviroment...less something like Virtual PC.
Return to “XML Presentation Server & TAPI Server”
