automatic DTMF end to end
kenzo_DUP
Post by kenzo_DUP »
Hi anyone please help me.
how to generate automatic internal DTMF end to end
thanks
ruud
automatic DTMF
Post by ruud »
Auto DTMF is normally set in the trunkgroup :
in MGR: Trunk Group > Auto DTMF dialing on outgoing call
Although this is for external conversations. Any reason why you want to use it for internal calls also ? Calling to a voicemail number wil also activate DTMF.
Greetz, Ruud
kenzo_DUP
Post by kenzo_DUP »
it to sent a dtmf to open the door.
presently i have to program a feature key DTMF end to end to open the door.it is troublesome
Use DTMF suffixe, then enter your DTMF code
kenzo_DUP
Post by kenzo_DUP »
it does not work i has try funny
Do you see a MF button in your screen? Try pressing it.
kleva
DTMF
Post by kleva »
Note: The DTMF Prefix only works on trunks, will not work for extensions.
How is the Door release mechanism connected? Trunk/Extension?
KLEVA
iourid
Post by iourid »
If it is analog extension put VSI Transparency=True.
kenzo_DUP
Post by kenzo_DUP »
you mean the analog phone connect to the door phone?
thanks
kenzo_DUP
Post by kenzo_DUP »
how abut digital extension?
Return to “ON SITE TROUBLES”
