take switch back to factory default settings
prodoor
Post by prodoor »
is there a command to erase a configuration on a switch back to the factory default?
benny
Re: take switch back to factory default settings
Post by benny »
Delete the boot.cfg from the "working" and "certified" directory and reboot. If you want to reset the password to factory default, delete the "userTable" from the "network" directory.
-b
