We have a configuration issue with a Spectralink NetLink 8020.
PBX (R9) with SVP server.
Alcatel MIPT phones (300,600) work just fine, but when trying to connect a Spectralink Netlink 8020, using the same setting as alcatel ones, the following error message is displayed:
"No GW Response"
Could this be because of the telephony protocol?
Alcatel works with "31" but this protocol can't be selected on the Spectralink phone (only 30).
Issues with Spectralink Netlink 8020
- tot3nkopf
Re: Issues with Spectralink Netlink 8020
For sure.
bcobarrubias
You need "TFTP download server" put "NONE" in the menu of SVP server
Alpha wrote:Hi,
"No GW Response"
simonwatson
Apologies if you already had an answer on this.
You can not install Polycom/SpectraLink 8020/8030 devices on OXE or OXO: the only such handsets made by Polycom/SpectraLink that you can use are the ALU-branded 310 & 610 which incorporate the NOE protocol.
Rgds
Simon
Rgds
Simon
