Baby listening feature
selectt_DUP
Post by selectt_DUP »
Customers old pabx had a baby listening feature on their old BT system and have asked if this available on their OXO system.
Any ideas how to impliment a intrude facility, note the bedroom handsets are analogue ?
thanks in advance
Re: Baby listening feature
I think this is possible only with digital sets.
A workaround would be to use parallel analog sets with hands free function and simply unhook 2 of them.
I think this is terminal (analog phone) feature - when you call this phone (like answering machine) you have automatic answer and via DTMF code activate "listening".
selectt_DUP
1. how do you activate auto answer on a ananlogue phone ?
i thought this was only a feature on digital handsets.
2. what code do you use for listening ? if you get through ?
thanks
I say about phones f.e. like Panasonic KX-TCM438 (answering machine) - you programm access code, select auto answer mode - and can call to this phone, after answer enter code and feature prefix (f.e. for this phone - dial 6 and 30 sec you can listen).
murraya
Post by murraya »
Some old system I worked on had the feature called baby monitor on analogue sets. What you did was take phone off hook and dial a prefix. When you wanted to check on the room you dialled the phone extn number and were put into a call so you could hear what was going on in the room. Not sure if possible with the OXO but maybe you could experiment with meet me conference? Lift handset start the conference then from another phone join the conference. That my do what you want. give it a go maybe.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “Hotel mode”
