Switch doesn't boot 9related to LEDs)
afterstep
Post by afterstep »
Sorry for stupid question,
but I'm in trouble. I've used forum search (and google search too) but I didn't find answer
"Power off" has heppened during "reset to factory defaults".
Now LEDs indication is: bps is solid green, other LEDs are dark.
Slot indicator LED shows "0"
Console port does not respond (or shows nothing)
Could anyone help me what I can do?
Does anyone has similar experience?
Thanks in advance
Rens_DUP
Re: Switch doesn't boot 9related to LEDs)
Post by Rens_DUP »
Hello afterstep,
If you are sure you have the right cable and don't see anything during a powercycle, not even a small boot message, I'm afraid you switch needs to be repaired or replaced by Alcatel-Lucent. Sorry
Rens
benny
Post by benny »
Is it an OS6850 or OS6800? Did you upgrade the code prior to the issue? Did you do a "newfs /flash"?
-b
afterstep
Post by afterstep »
benny wrote:Is it an OS6850 or OS6800? Did you upgrade the code prior to the issue? Did you do a "newfs /flash"?
It's 6850 after "reset to fatory defaults".
Console cable is (or was?) proper - it was used for reseting.
Somebody has taken power off after reseting and switch hasn't written anything into console...
I hoped something else is possible - before I'll ask service center.
Thank you for your answers.
