IP handsets are rebooting
tomy.alu
Post by tomy.alu »
Dear all,
I have a problem in IP handsets installation; please have a look below my details.
I have been installing 4018 IP handsets in OXE with the release of Rel : 6.1.1. My handsets are coming to in-service, But the IP hand sets are rebooting frequently.
While booting the handsets I can see an error that 
"getting load: Failed"
"getting data: Failed"
R6.1.1-f2.502-5-et-c6s2
Business identification: R6.1.1
DELIVERY: f2.502
Static patch: 5
Dynamic patch identification: none
CPU: c6s2
Please help me out if anyone about this issue.
With regards
Tomy
tincho.rn
Re: IP handsets are rebooting
Post by tincho.rn »
Hi. First of all, try to post under the correct index. I moved you topic to this index.
Second: your release is somehow old and perhaps those type of phone set are not supported. So, check hardware compatibility. Maybe you will need to install the last patch.
Regards.
Split
Post by Split »
hi
i know this behavior from Relaese 7 with 40x8 Extended Edition. I had installed the newest patch so it works fine. may you must install the newest patch. Otherwise disallow "Reset for update":False under TCP/IP User , so the 40x8 wokrs with the wrong binary. I doesent know if there disadvanteg.
for more information : TG0028-ed03
