Inter Vlan omniswitch 6400-P48
avrilspirit
Hello, sorry for my english but i am french.
i would like to do test with this switch but i have some problems...
I have put one ip adress to my switch :
ip interface vlan_1 address 192.168.1.1 vlan 1
After I have created 3 vlans like this :
vlan 2
vlan 3
vlan 4
ip interface vlan2 address 192.168.2.1 vlan 2
ip interface vlan3 address 192.168.3.1 vlan 3
ip interface vlan4 address 192.168.4.1 vlan 4
vlan 2 port default 1/4-5
vlan 3 port default 1/6-10
vlan 4 port default 1/11-15
I have 3 computer 1 in Vlan1, one other in Vlan2 and the last in Vlan3.
i would like to authorize le computer 2(vlan3) to speack with the 3 (vlan 4)
can you help me ?
vlan 2
vlan 3
vlan 4
can you help me ?
cedric1
Re: Inter Vlan omniswitch 6400-P48
hi
by default there is no restriction for routing
gateway + ip on your pc match ip of each vlan ?
put to forum show ip interface and ipconfig of each pc
Cedric
Cedric
avrilspirit
this is my configuration :
PC1
the same for the others with :
PC2
192.168.3.2
255.255.255.0
192.168.3.1
PC3
192.168.4.2
255.255.255.0
192.168.4.1
ow i would like for example : join PC3 to PC2 (but not in the same VLAN)
a communication Inter Vlan.
thanks for all
PC1
PC2
192.168.3.2
255.255.255.0
192.168.3.1
PC3
192.168.4.2
255.255.255.0
192.168.4.1
thanks for all
benny
Connect the PCs to the switch and assign the corresponding vlan to the port as "default vlan"...
-> vlan 2 port default 1/2
-> vlan 3 port default 1/3
-> vlan 4 port default 1/4
PC 1 = vlan 2 (connect on port 1/2)
PC 2 = vlan 3 (connect on port 1/3)
PC 3 = vlan 4 (cpnnect on port 1/4)
You can ping the PCs now - according to your IP settings. Make sure to allow ICMP in your Windows Firewall as it usually drops the ICMP ECHO-REQUEST by default and therefore won't answer.
-beny
-beny
avrilspirit
ok thanks
and if i would like to do a vlan with mac address, what is the process ?
benny
A vlan with MAC address?
I'm afraid I don't understand what you mean ....
Please explain in detail what you would like to achieve.
-benny
-benny
avrilspirit
I would like that,when i plug in my computer link (rj45) to the switch. The switch analyse the mac adress of the computer and directely reconize the vlan. I won't process with one port one vlan... i think it's possible, no ? and it's more easy for me... because after i have a lot of computer and i don't know exactely where i must plug in them...
cedric1
hello
you need to use mac rule and vlan mobility feature.
I suggest you to read networking manual.
In the post of beeny you have link to acces to theses docs
Cedric
Cedric
avrilspirit
Thanks Benny and Cedric
Yes i have try for the MAC it’s ok now, i have understand
But now i have try to do the same thing in a real case but i don’t understand why it’s don’t work.
Start :
ip interface « vlan 1 » address 192.168.91.1 vlan 1
Aaa authentication http local
And after i will go in my IE with the address http :192.168.91.1
After : - layer 2 ; VLAN Mgmt ; VLAN Configuration ; VLANs
I create 4 vlan :
I attribute port to each VLAN :
VLAN1 : port 1 ;13 ;14 ;15 ;16…
VLAN2 : port 2,3,4
VLAN3 : port 5,6,7,8
VLAN4 : port 9,10,11,12
Ip network address rules :
And after i create in layer 3 the ip route in « interfaces »
Now i plug in 3 computer like this :
and in each computer, the network interface like this :
PC2(VLAN2 port3) : 192.168.92.3 / 255.255.255.0 / 192.168.92.1
PC4(VLAN4 port 11)) : 192.168.94.3 / 255.255.255.0 /192.168.94.1
And i test to ping PC3 to PC4 and no repsonse…:(
Start :
I create 4 vlan :
VLAN2 : port 2,3,4
cedric1
enter
vlan port mobile slot/port-port
this command permit to trigger the port to mobility feature
