call restrictions on guest extensions
jellis_DUP
Post by jellis_DUP »
Oxo R7 in hotel mode.Is it possible place incoming and out going restrictions on only one guest extension,eg.the extension can only make calls to the one number and recieve calls from that same number
Re: call restrictions on guest extensions
It is possible if you define a certain barring table with this number.
jellis_DUP
thankyou for your answer.I understand how to do this for outgoing calls,but am still confused for incoming.The client has PRI with DID.I wish to block guest DID num from recieving all calls except for calls from one particular external number?
Hmm...OXO does not have a blacklist (filtering table like OXE has). Don't know if this is possible, even using workarounds.
Gents any ideas regarding this?
et
Post by et »
OXO have a black and whitelist. Feature called Selective diversion.
jellis_DUP
THX et i will have a play with this :D
Return to “Hotel mode”
