BIOS for CPU6 s 2
Vnbadiger
BIOS for CPU6 s 2
Post by Vnbadiger »
Do anyone know how to load bios on to CPU6 board.
Pls can mail me the bios file to upload on CPU6 board vnbadiger@rediffmail.com
During software installation bios will be updated automaticly.
If the bios is being flashed, you'll also see a message telling you that you need to do a HARD RESET (turn off the power on the CPU)
Vnbadiger
Post by Vnbadiger »
Yes Frank, I did that. When I restarted it the CPU 6 it was not booting up ,no incidents on hyperterminal and Ethernet led was not on whereas on my laptop it should the ethernet link is up (it was direct connection onto the CBRMA connection box).
Any jumper setting required for it to boot. pls let me known I am in dip shit for it.
Do you see the bios coming up ?
Can you past the log in here ?
(I mean the screen that you have when it starts / stop)
vali4715
Post by vali4715 »
My CPU6s2 are stopped sometimes, if you linked on serial, you`ll see that it is in Monitor Main Menu and if you search in CMOS management, it doesn`t see its HDD. If you stop and you restart from ON/OFF, the Alcatel starts like nothing happened and no incidents into.
What do you think about this?
Is this similary with Vnbadiger`s problems?
HDD was changed and didn`t change anything.
Vnbadiger
Post by Vnbadiger »
I dont see any incidents of CPU booting, which we all see during booting stage.
No ethernet led whereas on laptop network connection shows on. absolutly no activity on CPU.
vali4715
Post by vali4715 »
My defective CPU is different that you said. Advice: change CPU and test it at your workplace.
Return to “GENERAL”
