Can anyone explain why the following error occurs when attempting to modify the access type on Digital Access 1?
Processing Failure
OBJECT -1: T0/T2 Access No.: Cannot modify the type of the access, already i
Need to change from T1 CAS to T1 CCS. "Trkstat 0 24 1 " shows Access 1 is enabled. This Access was previously configured for QSIG to Nortel switch; I need to reconfigured for new T1 PRI with T1 CCS signaling.
Your help will be appreciated.
-ksm-
ksm
Thanks for your responses; however, the problems is not solved yet.
X25 Synchronization is disabled for the trunk grp; however the following error occurs when attempting to delete the trunk grp:
OBJECT -1: Trunk Group Id: Trunk(s) assigned to this trunk group
And the following error occurs when attempting to delete any trunk assigned to the trk grp:
OBJECT -1: ATTRIBUTE 0: Cannot put the terminal out of order
-ksm;
-ksm;
ksm
